VIP flapping/fluctuation between 2 load balancers
gnizamuddin
I have 2 load balancers which are supposed to work in active-standy fashion. The load balancers had been working fine till last 2 days (for a couple of years). However, I faced an outage because of continuous VIP flapping on these load balancers on Saturday. This VIP is the default gateway for my servers; hence because of flapping the load balanced services were inaccessible for these servers. I could only see these messages in logs:
LPKPK11# sh log sys.log
  sys.log                         OCT 13 19:49:38        4200058
  sys.log.prev                    NOV 12 21:07:38        9999963
OLD LOG MESSAGES HAVE BEEN SAVED in associated .prev file.
NOV 12 21:07:34 1/1 1425645 IPV4-4: Duplicate IP address detected: 172.16.13.5 68-ef-bd-a0-ad-ba
NOV 12 21:07:34 1/1 1425646 IPV4-4: Duplicate IP address detected: 172.16.13.5 68-ef-bd-a0-ad-ba
NOV 12 21:07:34 1/1 1425647 IPV4-4: Duplicate IP address detected: 172.16.13.5 68-ef-bd-a0-ad-ba
NOV 12 21:07:34 1/1 1425648 IPV4-4: Duplicate IP address detected: 172.16.13.5 68-ef-bd-a0-ad-ba
NOV 12 21:07:34 1/1 1425649 IPV4-4: Duplicate IP address detected: 172.16.13.5 68-ef-bd-a0-ad-ba
NOV 12 21:07:34 1/1 1425650 IPV4-4: Duplicate IP address detected: 172.16.13.5 68-ef-bd-a0-ad-ba
No virtual router was being seen by both load balancers:
LPKPK11# sh redundant-vips
Redundant-Vips:
Interface Address: 172.16.13.5      VRID: 31
  Redundant Address: 172.16.13.27       Range:       1
  State:             No Virtual Router  Master IP:   172.16.13.5
  State Changes:     3,562              Last Change: 10/13/2012 19:45:35
Interface Address: 172.16.197.122   VRID: 10
  Redundant Address: 172.16.197.81      Range:       1
  State:             No Virtual Router  Master IP:   172.16.197.122
  State Changes:     3,563              Last Change: 10/13/2012 19:45:35
  Redundant Address: 172.16.197.82      Range:       1
  Redundant Address: 172.16.197.84      Range:       1
  Redundant Address: 172.16.197.85      Range:       1
CPU and memory status was normal:
# sh system-resources
System Resources for CSS501-SCM-INT:
Installed Memory:   268,435,456 (256 MB)
Free Memory:        137,464,384 (131 MB)
CPU:                0% (5Sec)     5% (1Min)     3% (5Min)
Buffer Statistics:
Buffer Pool: 0
   Size:2048  Total:3072  Available:2776  Failures:  0  Low Buffer Count: 2084
Buffer Pool: 1
   Size:2048  Total:3072  Available:2832  Failures:  0  Low Buffer Count: 2832
Buffer Pool: 2
   Size:2048  Total:2048  Available:1944  Failures:  0  Low Buffer Count: 1856
I observed preempt (but with different priority) on different Circuit VIPs on both LBs which I turned off on secondary LB. The problem didn't resolve.
I turned off the critical services. That also didn't help.
I rebooted both LBs; but also in vain.
Eventually, I had to shut down one LB to restore the service. Here are the IP configs on both LBs:
LB1:
!************************* INTERFACE *************************
interface e1
  bridge vlan 31
interface e2
  description "Signaling uplink on LPKPK11 towards S9309-A1 Eth-1/0/33"
  bridge vlan 40
interface e5
  description "Inter-CCS Communication towards other LB Master-Slave Mode"
  isc-port-one
interface e6
  isc-port-two
interface e7
  trunk
  vlan 2
  vlan 3
interface e8
  description "to SW11-Gi0/18"
  bridge vlan 3
!************************** CIRCUIT **************************
circuit VLAN31
  ip address 172.16.13.5 255.255.255.0
    ip virtual-router 31 priority 110 preempt
    ip redundant-interface 31 172.16.13.4
    ip redundant-vip 31 172.16.13.27
    ip critical-service 31 upstream_downstream
circuit VLAN3
  ip address 172.16.197.122 255.255.255.192
    ip virtual-router 10 priority 110 preempt
    ip redundant-interface 10 172.16.197.120
    ip redundant-vip 10 172.16.197.85
    ip redundant-vip 10 172.16.197.84
    ip redundant-vip 10 172.16.197.81
    ip redundant-vip 10 172.16.197.82
    ip critical-service 10 upstream_downstream
circuit VLAN40
  ip address 172.31.96.5 255.255.255.240
    ip virtual-router 40 priority 110 preempt
    ip redundant-interface 40 172.31.96.4
LB2:
interface e1
  bridge vlan 31
interface e2
  description "Signaling uplink on LPKPK12 towards S9309-A2 Eth-1/0/33"
  bridge vlan 40
interface e5
  isc-port-one
interface e6
  isc-port-two
interface e7
  trunk
  vlan 2
  vlan 3
interface e8
  bridge vlan 3
circuit VLAN31
  ip address 172.16.13.7 255.255.255.0
    ip virtual-router 31 priority 90
circuit VLAN3
  ip address 172.16.197.121 255.255.255.192
    ip virtual-router 10 priority 90
circuit VLAN40
  ip address 172.31.96.6 255.255.255.240
    ip virtual-router 40 priority 90
I need urgent help from Cisco CSS experts here. Awaiting for your kind feedback.
Nizam
chrhiggi
Level 3
Level 3
Nizam-
  Depends on what code you are running....but sounds like a match for CSCek37489 where the standby CSS forgets it is supposed to be standby after 828 days of uptime.
Chris Higgins
Cisco ANS TAC Escalation
Thanks Chris. Can you send me a reference for this bug's fix?
Also, I rebooted both load balancers but the problem prevailed. If the problem is due to this bug, the reboot should have refreshed the uptime counter of both load balancers and the problem should have been fixed.
BR
Nizam
Symptom:
Backup CSS may send VRRP packets suddenly and then both CSSes goes Master status.
Conditions:
This symptom is observed on CSS that runs about 828 days.
Workaround:
Rebooting the CSS.
Fixed-In:
Fixed-in7.50(3.3)
8.10(2.5)
8.20(0.1)
5.0(6.16)S
7.50(2.11)S
8.10(1.11)S
6.10(4.18)S
7.40(3.9)S
