Vwaas Solution and Appnav XE integration
Ario M. Fanie
Dear Cisco Support,
This is my first time for sizing waas, i want to ask few questions. I am designing for 500 remotes routers and 4 DC ASR routers - 3 DRC ASR routers, Wave as central manager in DC and DRC.
1. What happen when the connection of users are greater than maximum connection capability of ISR WAAS / waas express in branches area ?
in the remotes areas, using ISRWAAS SSD 4321+ / 1941+waas express
2. In the DC, i am going to use 4 server vmware installed vwaas 50 K, and appnav in all 4 ASR routers
I am assuming for the appnav-xe for this solution. Several questions :
2.1. How to implement appnav-xe with server vwaas interconnection ? The document seems separeted and not really detailed.
2.2 For the interface virtual in server VWAAS, Can this be mapped to the vmware networking ? I can not find a complete tutorial for this matter.
in DRC, i am going to use 3 server vmware installed vwaas 50 K, and appnav in all 3 ASR routers
3. The connection for the DC and DRC will be active-active, What are the best solutions for the high availability and active-active solutions.
4. What are Switch configuration to waas server configuration ? Right now using cisco 3850 IP base
I have attached the network diagrams.
Thank you
Hi Ario,  Sorry that you have not received any replies on this yet.  I am working on a similar project.  More of a full hardware replacement (Dual 2821(EOS) > Dual ISR 4331.  I have the hardware in a lab and I have been working on IWAN(DMVPN) and WAAS.  No where near the scale you have.  I doubt that I can answer many of your questions.  I can commiserate on what seems to be disconnected or unclear documentation but that is the struggles of doing oneself and not simply hiring a VAR.  ;-)
Q1) I did read somewhere that connections over the limit are simply not optimized.
Sorry on the other questions.
