WAAS 4.1.1 EPM and MAPI
JHaynes4
I am going to be upgrading a current WAAS
implementation from 4.0.13 to 4.1.1. In 4.0.13 EPM was turned off because of all the issues it created. My question is has anyone used the WAAS 4.1.1 version with EPM and MAPI and noticed any issues. Thanks in advance.
6 Replies 6
Excellent, thanks. I was planning on using 4.1.1.c anyway so hopefully there are no "new" issues introduced into EPM.
I've had to disable epm and mapi on my boxes. lots of problems.
Interesting. Since I've upgraded (about a month ago) I've seen excellent EPM, MAPI performance but I have actually had a few cases where the Http AO caused an issue with our proxy server that required an WAE reboot.
Sounds like you are encountering the same bug that I was with the HTTP AO. I had to disable the HTTP AO and now everything is working fine. The bug ID is CSCsv69306.
Thanks for the reply. That is indeed what we saw.
