WAAS and Routers running HSRP
I am just in the process of deploying WAAS across our network. I have found that when the WAN router that is running WCCP has been configured for HSRP and is the active router i see the following
If I try and telnet to the HSRP standby address it does not connect and I get the following error message :
Jan 30 18:04:36.930 AU-Summ: %IP-3-LOOPPAK: Looping packet detected and dropped
src=172.16.33.254, dst=172.16.9.251, hl=20, tl=72, prot=47, sport=0, dport=0
in=GigabitEthernet0/0.9, nexthop=172.16.9.251, out=GigabitEthernet0/0.9
options=none
-Process= "IP Input", ipl= 0, pid= 82
-Traceback= 0x611B33C0 0x616A0FD4 0x616A11E0 0x616A1C14 0x616A1FE4 0x6168D09C 0x
6168E880 0x6168C384 0x6168C648 0x6168C704 0x6168C8A8
f I telnet to the actual router address then ok.
is this a Bug?
just seen other question about HSRP and tried the
"egress-method negotiated-return intercept-method wccp' command but made no difference
see router interface configuration below
Note if no HSRP then no problem
interface Loopback0
ip address 172.16.33.254 255.255.255.255
interface GigabitEthernet0/0
description trunk to Cat 6509
bandwidth 100000
no ip address
duplex auto
speed auto
media-type rj45
negotiation auto
ntp broadcast
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.1.100 255.255.255.0
no snmp trap link-status
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 172.16.2.250 255.255.255.0
ip wccp 61 redirect in
ip flow egress
interface GigabitEthernet0/0.3
encapsulation dot1Q 3
ip address 172.16.3.250 255.255.255.0
interface GigabitEthernet0/0.5
encapsulation dot1Q 5
ip address 172.16.5.252 255.255.255.0
ip pim sparse-mode
standby 5 ip 172.16.5.254
standby 5 preempt
service-policy input prec
interface GigabitEthernet0/0.6
encapsulation dot1Q 6
ip address 172.16.6.252 255.255.255.0
ip helper-address 172.16.5.228
ip accounting output-packets
ip pim sparse-mode
standby 6 ip 172.16.6.254
standby 6 preempt
interface GigabitEthernet0/0.7
encapsulation dot1Q 7
ip address 172.16.7.252 255.255.255.0
ip pim sparse-mode
standby 7 ip 172.16.7.254
standby 7 priority 105
standby 7 preempt
interface GigabitEthernet0/0.9
description testlan for WAAS
encapsulation dot1Q 9
ip address 172.16.9.254 255.255.255.0
ip wccp redirect exclude in
Richard,
The problem you are reporting is CSCsg30875. You can work around this issue by defing a redirect-list that denies traffic destined to the IP address(es) of the router itself.
Zach
