08-18-2010 07:50 AM
Hi all,
I want to know if there is some design guide or reference to follow about WAAS implementation with IP telephony.
I've implemented WAAS in a customer's network with a central site and 20 remote offices and after that there are some problems with the telephony, specifically with call signaling. There are Cisco IP Phones in the branch offices, with a UCM in the central site and there are too FXS and FXO cards with analogic phones in the remote office.
Thanks for your comments.
Guzmán
Solved! Go to Solution.
08-18-2010 08:36 AM
Hi Guzman,
What version of WAAS did you deploy? the images below are form 4.2.3...
By default, call signaling in the Ip telephony world, is not optimized by WAAS according to the default policy entry in the default policy template.
08-18-2010 08:36 AM
Hi Guzman,
08-18-2010 09:44 AM
Hi Manuel, thanks for your help.
I have 4.1.5f in all my WAEs. The screen-shoots that I can see in your answer, are from predefined configuration in WAAS systems?
Guzmán
08-18-2010 09:48 AM
Hi Guzman,
Yes the screenshots belong to the policy template ( default) .
This policy entry and the entire policy can be customized..ie..add more ports to the Call monitoring clasifier.
version 4.1.5e has issues....maybe move to version 4.2.3.
regards,
Manuel
