WAAS Network Module IP address question
Tod Larson
Level 3
Level 3
I've read the instructions for configuring a WAAS Network Module but I don't understand what IP space I'm suppose to use.
https://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v403/module/configuration/guide/wsnmecfg.html
My 2821 has g0/1 as the LAN connection and s0/1 as the WAN link
g0/1.1 - 10.1.1.1 /24
g0/1.4 - 10.1.1.4 /24
s0/1 - 192.168.1.1 /30
Do I need to allocate a new subnet for interface service-engine1/0?  Or can is be an IP address in my 10.1.1.1/24 subnet?  What's the best practice?
If it's a new subnet then I assume I need to add it to eigrp, right?
Here is the sample from the Configuration Guide...
ip address 10.0.0.20 255.255.255.0  <--- does this have to be it's own subnet, what's best practice?
service-module integrated-service-engine ip address 10.0.0.30 255.255.255.0 <-- this has to be in the same subnet as above, right?
service-module integrated-service-engine ip default-gateway 10.0.0.20 <-- is this always the "int service-engine1/0" IP?
Sorry for the shotgun question approach.  Thank you in advance.
Zach Seils
Level 7
Level 7
Hi Tod,
The most common scenario is to allocate a new subnet for the module.  Since the module will need IP connectivity to the Central Manager, you should advertise it via EIGRP (or whatever routing protocol you are using).
Here are the answers to your command specific questions:
> See above.  The most common scenario is to allocate a new IP subnet.
> Yes.  This is the IP address that is assigned to the NME-WAE.
> Correct.
Zach
Zach Seils
Level 7
Level 7
Hi Tod,
> Correct.
Zach
