WAAS/WAVE snmp monitoring of TCP connection count
hgans
hi everyone,
i'm wondering if it's possible to query the amount of TCP connections via snmp, that are handled by a wae.
it's an important characteristic value to check if optimization is working properly.
looked over the several MIB documented in the latest config guide, but unfortunately got no clue...
can anyone help?
thanks in advance!
Zach Seils
Level 7
Level 7
This statistics is currently not instrumented through SNMP.  You can, however, access this statistics through the following methods:
  • CLI
  • XML API
  • Transaction Logs
Zach
