WAE-274 Connection limit
fast5658659
Hi All,
        I am getting Connection limit = 10 under policy engine statistics. Cisco says "The "Connection Limit" counter under the policy engine statistics reports the number of connections rejected and passed through because the WAE has exceeded its rated number of optimized TCP connections. If this counter is high, it means the WAE is frequently getting more connections than it can handle."
Is this normal to have Connection limit to 0 - 20
ahskhan
   Connection Limit    : under Rejected Connection Counts Due To: shows how many connections were rejected due to connection limit,
Total number of available / Effective connection limit can be checked by this command  "show tfo detail".
If you see Active connections close to total number of Effective Limit then it would explain the "Connection Limit" counter increment.
Ahsan Khan
