WAE 474 disk problem
simsekhasann
Community Member
i have a problem and not found any information.
i search support sites, generally wae problem raid problem etc. disk01 or disk00 corrupted problem.
my wae have just one disk and problem was there my opinion. when i use cms command fail.
WAAS(config)#cms enable
sh: /sw/merlot/bin/spen: No such file or directory
FAILED to enable management services
WAAS(config)#
and this is disk detail.
WAAS#show disks details
Physical disk information:
disk00: Not used (*)
(*) Disk drive won't be used until replaced.
Mounted file systems:
MOUNT POINT TYPE DEVICE SIZE INUSE FREE USE%
No RAID devices present.
Disk encryption feature is disabled.
WAAS#
what s your suggest?, thank you.
Philip D'Ath
Meraki Community All-Star
Hopefully you have a support contract on the device (otherwise get one). I think you are going to need TAC for this one.
