WAE Edge is showing offline
asfar.zaidi
Hi All
I have a design where all my WAE are inline in the path of traffic .
One of my WAE Edge shows on the CM as offline and after half an hour it comes online , again it went offline after 1 hour and so on.
What might be the issue and when its offline I can not even remotely telnet to the management intrerface of WAE but its keep on by passing the traffic.
Any body face the same issue , the problem with hardware or any suggestion.
asfar.zaidi
Very interesting finding
1- Branch WAE Edge status on CM GUI is offline.
2- Unable to telnet Branch WAE Edge remotely.
BUT
1- Able to telnet Branch WAE Edge from the local netwrok.
2- When I telnet and check the cms info of Branch WAE Edge its showing 'inline'.
3- Branch WAE Edge is intercepting the traffic and optimizing and accelerating the traffic.
Any body can shed light on this issue why I am getting status off line on WAAS CM for this Branch WAE Edge.
Just to provide all experts and viewers more insight to the problem
my Branch WAE Edge is Cisco WAVE-574-K9 Platform running with WAAS version 4.1.1c (build b16 Nov 5 2008) software.
