WAEs CAUSE HIGH CPU LOAD ON ROUTER 7609
gbruque99
We had deploy a wae (7341) cluster at this time 2 waes, they are serving wccp web cache and spoofing services, we see the router 7609 increases its cpu load at 55% average and more during the peak hours,we want to know what we can do in order to reduce the router's cpu load
Thanks for your help.
6 Replies 6
tblancha
Is CEF turned on? Did you configure a service for out? If you are doing an out, then this is a process switched event. Look to do 61 and 62 in on the interfaces instead of anything out.
Yes Cef is ON,
On the interfaces the services wccp are configured like this
ip wcc web-cache redirect in
ip wccp redirect out
The 7609 has a supervisor engine WS-SUP720-3B
What is the egress method you are using? Can you send us the output of 'show egress-method' from the WAEs that are attached to 76xx having spike in their CPU usage?
Hi, thanks for the help
This command is not supported by the WAE. We have a Wae 7341, ACNS 5.5.13
The WAE's had not experienced cpu high load neither spike.
What about to change the Supervisor Card from the 7609 router ?? Fron the current WS-SUP720-3B to another one..the question is wich one??
Sorry, I didn't know you are using 7341 as ACNS device. I would not recommend changing the h/w at this point. Can you pl email me 'show tech' from the 7341. My id is nchidamb@cisco.com.
I send you the information requested about WAE.
