Hi all,
I've configured a vlan interface in a Catalyst 3850 with two services, web-cache and dynamic service 95. According to the info extracted from this forum, both services are redirected in, in the same interface.
The result is that traffic is being redirected correctly, I see every request in the WSAs logs, but the problem is that IP Spoofing is not being done correctly because using tcpdump in the exit interface, I am able to see only the WSAs IPs.
Traffic is configured as "Return" in the WSA and everything is correclty set as it can be seen when checking it doing "sh ip wccp <service number/name> details" in the switch, redirection is established using L2 and Mask assignment.
Am I missing something?
Regards.
