wccp issue
raj.bansal
Community Member
Here is my topology
6500A ---dot1q-----6500B
Cache Engine
The cahce engine has two interfaces, one one each switch. Both are configured to listen to incoming request.
If i have a host connected to a module which is a fiber only card with DFC on switch 6509A, and i make a web request, the request is redirected but i get a reset issued and web pager doesn't come up. Is there any issue when DFC are inovlved in a WCCP scenario?
Thanks.
Raj
Gilles Dufour
there should be no problem with DFC and WCCP.
Is the CE generating the reset ?
Does it come immediately after sending the SYN ? or does it come later in the trace ?
Gilles.
