WCCP with Layer2
Amol Akadkar
Community Member
I want to configure WCCP on Layer2 Redirection on Cisco Router 3800, but only GRE mode is working layer2 redirect is not comming up.
Cisco Router Details: Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(15)T7, RELEASE
Proposed diagram is attached.
WCCP will be configured on LAN Interface of Router.
Observation: if cashing engine connected on (L3 Switch) LAN side of router, Layer2 Redirection is working fine. But if cashing engine connected on additional interface of router layer2 mode is not working.
7 Replies 7
nkarthikeyan
Level 11
Level 11
can you share you configurations @ you router?
also if poosible paste the parameters you have set on caching engine?
Karthik
Hi Karthik,
Please find commands on Router as below and WCCP configuration on Cashing Engines screen is attached --
Router Configuration
Router (config)# access-list 101 permit ip 172.60.10.0 0.0.0.255 172.80.10.0 0.0.0.255
Router (config)# ip wccp 53 redirect-list 101
Router (config)# ip wccp 54 redirect-list 101
Router (config)# interface FastEthernet0/0 (LAN Interface of Router)
Router (config)# ip wccp 53 redirect in
Router (config)# ip wccp 54 redirect in
Router (config)# end
Hi Amol,
Have you tried enabling accelarated command in global command?
Karthik
Hi Karthik,
Thanks for quick response.
Issue is WCCP Layer2 is Initializing. If mode change it to GRE then it works fine.
Amol
Hi Karthik,
Any update on the issue.
I have very limted option to try out in lab.... let me try my best to figure out the issue..
Karthik
Amol Akadkar
Community Member
Hi Karthik,
Amol
