WebSense not accessible/functioning when CSS configured
anup_bekal
Level 2
Level 2
I am trying to integrate CSS with NetApp cache engine. Everything works fine, except for the Websense.
Please find attached diagrams of present & planned network. In present network, Cache engine is integrated with Cisco Router using WCCP. Websense also was working fine.
In the planned network, I have integrated Cache engine with CSS for transparent proxy, everything works fine except for Websense.
When I am trying to access Websesnse server using Remote Desktop from the user1 & user2 machines it is not allowing me to do so. Also if I am trying to access web sites that are blocked by the Websense, it is not getting blocked, but just hangs and then gives some search sites. Traffic is mirrored to Websense from the Fast Ethernet 0/12 port of Switch(192.168.161.5).
I am attaching the relevant configuration of CSS & the Cisco switch along with this. Do I miss something on the CSS that will make Websense work perfectly? Please advise.
(Real IP addresses for the devices in the diagram & configuration are changed into 192.168.161.0 network)
Thanks in advance.
Regards // Anoop
smahbub
Level 11
Level 11
Try - CSCeh37469
