Why LAN and WAN interfaces on Inline-Module?
hbettschnitt
Frequent Visitor
Frequent Visitor
What ist the reason for having interfaces named WAN and LAN on Inline-Moduls. Is it only for documentation or there a functional need? Will I get any problems if I connect the LAN interface to the WAN side and visa versa?
Michael Schueler
Yes, it is indeed required to connect the WAN-facing link to the WAN interface and the LAN-facing link to the LAN interface. Otherwise traffic optimization might not work correctly.
Please also make sure to following the cabling guidelines documented here:
http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/wae/module/inline/installation/guide/17880fru.html#wp39911
Michael
Michael Schueler
Michael
