el 10-05-2015 03:53 AM
I have purchased RV110W Wireless-N VPN Firewall.
I'm unable to block SSL (HTTPS) enabled websites using RV110W Wireless-N VPN Firewall.
Example: https://www.facebook.com
Please help me in resolving this issue.
Tanzeem
el 10-05-2015 11:58 AM
Hello tanzeem01,
Thank you for using the Cisco Small Business forums. My name is Cristian, I am an eContent developer and I am part of the Small Business Support Community. I found the following article in out database that might be of some assistance:
I hope you will find this answer useful, and I hope you reply back with any questions or concerns.
*Please mark the question as Answered or rate it so other users can benefit from it*
Cristian Gonzalez
Cisco eContent Developer
el 10-05-2015 10:19 PM
Hello Cristian!
Thanks for your help.
I tried all the steps and unfortunately, I'm still unable to block HTTPS websites. Please assist me in resolving this issue.
Tanzeem
el 10-07-2015 02:40 PM
I am sorry, it appears the HTTP/HTTPS option is for access to the Firewall. You should be able to block all HTTPS traffic using an Access Rule.
This can be found at Firewall > Access Rules.
You can then add a rule that Denies all traffic from HTTPS. Let me know if you have any questions.
el 10-08-2015 02:54 AM
Hello Cristian!
Thanks for your continuous support.
Under Firewall > Access Rules, we can create different "Access Rules".
However, we have only one option (Default Outbound Policy - "Allow / Deny") for all the "Rules".
If we select "Deny", then we be unable to use the internet as none of the websites will open. Example even "http://www.cisco.com/" will not open.
I have attached two screenshots. Please find the attached screenshots and help me in blocking HTTPS websites.
Tanzeem
el 10-13-2015 04:03 PM
I'm sorry, could you explain what you mean by having only one option (Default Outbound Policy - "Allow / Deny")?
I was able to successfully block HTTPS traffic with a rule that contained:
el 10-13-2015 10:26 PM
Hello Cristian!
Using "Internet Access Policy" and the keyword "facebook.com" as well as the URL "https://www.facebook.com", I'm unable to block facebook.com.
However, using "Internet Access Policy", I'm able to block the websites that are not SSL enabled, example www.msn.com.
Please assist me in blocking the HTTPS websites of my choice ex: "https://www.facebook.com".
Tanzeem
el 02-08-2017 05:02 AM
have you tried to disable the remote management feature?
regards
albert
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
