Initial thoughts...
Brian Bergin
Level 4
Level 4
The first question raised here is why is this switch even being considered for production?  We've not run CAT5/5e in 2+ years having run nothing but CAT6 even in the smallest of customers.  With full gigabit switches very cheap today, I don't understand why Cisco continues develop 100Base-T products, especially switching products.  The RV0xx 100Base-T ports are fine because we don't consider routers viable LAN switching devices. The only devices ever connected directly to a router other than an uplinked switch are VoIP devices (e.g. Vonage) or non-mission critical devices like webcams, but PCs are all connected via separate switches, but the need for 15 year old technology isn’t there any more when gigabit is not much more expensive, every PC supports it today (I’ve seen sub-$500 systems with gigabit NICs in them), and gigabit provides for a much longer life in what, based on Cisco’s other pricing, is likely to be an expensive switch compared to competitors.
IMHO, this is back to Cisco needing to reevaluate its product lines and significantly reduce the number of SKUs it has out there.  The cost alone of maintaining, supporting, stocking, marketing, etc… several different switches should easily supplant the small cost of gigabit over FE.
2) Noise is the #1 complaint I get for LAN gear and it seems as though this switch has its fans spinning at 100% no matter the load.  Can you not use temperature controlled fans?  Small businesses often do not have a dedicated wiring closet and as such their networking equipment is often in an office.  IMHO, this switch is too loud and will be returned all too often due to noise.
3) You should include a pre-defined SNTP server by default.  Personally, I'd start with time-a.nist.gov on 129.6.15.28.
4) You could save $ by simply not having the serial interface.  Small businesses can barely handle a GUI let alone a CLI.  This goes back to Cisco's lack of understanding of the small business market.  The serial cable will simply be discarded or otherwise lost and as such is just added cost with little to no benefit.
5) A documentation problem.  Page 4 states "Cisco strongly recommends using Cat5 or better cable for Gigabit connectivity."  The problem is gigabit is absolutely horrible on Cat5 not much better on 5e.  The statement should, IMHO, state, "Cisco strongly recommends using CAT6 or better cable for Gigabit connectivity."  In fact, you should also state that ends and patch cords need to match the left of the cable runs (I've replaced far too many ends where other vendors ran CAT6 in the walls and use CAT5 punch blocks and patch cords and the customer was having problems.  The LAN is going to perform to the lowest common standard).
6) As stated in the RV0xx beta, Cisco needs to decide on a default username/pwd combination.  The RV0xx uses admin/admin, Cisco Small Biz Pro uses admin/cisco.  For this device it's cisco/cisco and you can't change the "cisco" username to admin to better fit with others. Pick one, no one cares which one, but just pick one and stick with it.
7) Cisco Small Business (not Small Business Pro) must decide if it's going to save settings by default when you click Apply or if you have to click Save.  The problem is "Save" is VERY, I cannot stress this enough, VERY small and 99% of small businesses are NEVER going to see it let alone know they have to click it (you don't have to click Save on any of the Small Business routers like the WRV's or RV0xx's).  The first time a small business owner makes a bunch of configuration changes and doesn't click save but the power goes out and ALL his settings are gone will be the last time they buy a Cisco Small Business product.  Dell's save when you click Apply.  RV0xx save when you click apply.  SA500s save when you click apply.  Many of us have complained about the ESW500s not saving when you don't click "Save Configuration" (again, Cisco can't seem to get its terminology consistent between products).  Assuming Cisco's small business customers have the same level of experience and expertise as your Catalyst or ASA customers do is a mistake and one that Dell doesn't make.  Cisco has been making calls to VARs and resellers of late to find out more about now small businesses think (I belive I've done 2 or 3 of these 1.5 hour conversations), but I'm convinced Cisco has a long way to go.
8) Another documentation mistake.  The QSG says the device comes on 192.168.1.254 but you "must choose an IP address in the range of 192.168.1.2-192.168.1.253 that is not already in use."  First, 192.168.1.254 is a perfectly legitimate IP and need not be changed if it's 1) not already in use and 2) not planned to be in use. Second, you absolutely do not need to pick something on 192.168.1.0/24, our LAN is on 192.168.100.0/24 and it works just fine on 192.168.100.247.
6 Replies 6
Kurt Schumacher
Hi Brian,
After we had been challenged for in-depth testing a SG 300, and receiving an SF 300 I had asked if there was a mistake in the product planning, or something went badly wrong .
Was just on writing down the very similar thoughts and impressions. 100 Points - perfect, can't agree more!
-Kurt.
Brian Bergin
Level 4
Level 4
The Sx300-NikolaSales300Ext.pptx document in Documents says:
Fanless designs
Quiet operation and increased MTBF
Limited noise levels across entire portfolio
Gotta say this isn't quite and sure doesn't have limited noise levels!
It also lists 15 models!  I'm thinking 8, 16, 24, 48 ports and that's it is all Cisco needs and all gigabit and I seriously question the need for PoE.  If the ESWs are any indication of what Cisco will charge for their PoE units it's cheaper to buy injectors for the few devices a small biz might need PoE for (small biz's simply aren't deployig VoIP in any huge numbers) than to pay Cisco for a switch like this.
I can just judge based on the SF300-24P we have on test here:
  • much to noisy for in-office installations due to non-regulated fans
  • to noisy to install in comms cabinets located in offices, or behind light walls, or rooms with shared air condition
It's neither fanless, nor quiet. Probably three or four db less than a SWR, but this does not make a "limited nosie level", too. Not good for re-engineered hardware that should be competitive for the next three years or so.
Your competition has it: Fanless FE and GbE switches with more than 8 ports.
HP ProCurve Switch 1400 Series
HP ProCurve Switch 1700 Series
HP ProCurve Switch 1800 Series
...just to name a few...
Brian Bergin
Level 4
Level 4
Couldn't agree more.  I had to unplug our SF300-24P today to have a meeting becuase it was so loud (and I though the SA520 was loud).  IMHO, this is as loud as enterprise Cisco equipment and simply will not sell to small businesses.  We have 24 port Dell switches here (and 48 port Dell switches at customer sites) and while they're not silent either, they are quieter than this one and they're full GbE (and I'm betting they'll still be 1/2 the cost).  As a VAR I strongly urge Cisco to go back to the drawing board here, it's not a sellable product to an small business that doesn't have a sound proofed room for their switching equipment (it's louder than Dell PowerEdge 2900's that sound like 747's on take off when powered on then are very quiet unless really pressed for horsepower).
Your observation on the fan’s noise level is a valid concern. Though you may understand that some issue can be addressed quickly while others are not such as fan or hardware (re)design. However please rest assure that the issue you raised will not go un-noticed. I’d relayed your concern to design/management team. Thanks!
ddiep
Level 4
Level 4
Brian,
Each item in your "Initial thoughts..." is important and taken seriously.  Your comments had been presented to the supports/engineering team for further analysis and consideration. Thank you for your valuable input and ongoing EFT efforts.
-ddiep
