06-16-2010 08:37 AM
we are partner in india , kolkata. we are talking to all cisco sources to help in buying Protect Link Anti Virus Software that comes along with RV042 . No one is able to respond , need to some input here, any one who can help this to go ahead
Solved! Go to Solution.
06-17-2010 01:06 PM
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5739/ps5723/ps9952/ps9953/data_sheet_c78-502732.html has part numbers at the bottom of the page. Vendors like CDW.com have these PNs available for electronic order. That being said, if you've not used ProtectLink on a RV042 I strongly recommend you get a 30 day trial before you buy it. When we've had clients use it on an RV042 they've not been happy with performance.
06-17-2010 01:06 PM
06-17-2010 11:34 PM
thank you for this reply , good to know on the performance front. as per you answer it can not be bought from India , need to be purchased from distributor out of India.
06-18-2010 06:30 AM
Are you saying when you go to cdw.com you can't buy this from them?
06-18-2010 10:17 AM
No i am saying I am not able to buy from India Listed Distributors
