T.38 Re-Invite issue with multiple WAN interfaces
ryan.yaldor
Tested with version 1.02.01 (023) Aug 12 2011 as well as current.
When using multiple WAN interfaces and the voice is routed to WAN2, once the re-invite is processed, the SRP send the T.38 stream out the WAN1 interface sourced from the WAN2 IP address.
6 Replies 6
Andrew Hickman
Hi Ryan,
Thanks for the feedback.
How do you have your MultiWAN settings configured?  Do you have both failover and load balancing disabled?
Could you send a Remote Support Status file please?
Cheers
Andy
Correct, we have those both disabled.  Just forcing data to WAN1 and voice to WAN2.
...and a static route to the SBC via the WAN2 interface/gateway?
Correct.
Ok - please send the remote status file for us to look at.
Many thanks
Andy
ryan.yaldor
As an added note, we have verified that if we put a static route in to our SBC's to use the WAN2 interface, calls complete successfully.
