Stack switch 2 restarted, and generated the following logs
.Aug 30 18:39:13 BRST: Config Sync: Line-by-Line sync verifying failure on command:
30 deny ip any any log
due to parser return error
.Aug 30 18:39:14 BRST: %RF-5-RF_RELOAD: Peer reload. Reason: Configuration mismatch
.Aug 30 18:39:14 BRST: %PLATFORM_HA-4-RELOAD_PEER: Reloading the Standby, due to Config-Sync (Configuration mismatch)
.Aug 30 18:39:14 BRST: %STACKMGR-1-RELOAD_REQUEST: 1 stack-mgr: Received reload request for switch 2, reason Configuration mismatch
Aug 30 18:39:14 BRST: %STACKMGR-1-RELOAD: STANDBY:2 stack-mgr: Reloading due to reason Configuration mismatch (SWCOREMFALS-2)
.Aug 30 18:39:15 BRST: %STACKMGR-1-STACK_LINK_CHANGE: 1 stack-mgr: Stack port 1 on switch 1 is down
.Aug 30 18:39:15 BRST: %STACKMGR-6-SWITCH_REMOVED: 1 stack-mgr: Switch 2 has been removed from the stack.
.Aug 30 18:39:15 BRST: Starting SWITCH-DELETE sequence, switch 2
.Aug 30 18:39:15 BRST: SPI(FED QoS) server dead
.Aug 30 18:39:15 BRST: %REDUNDANCY-3-STANDBY_LOST: Standby processor fault (PEER_NOT_PRESENT)
.Aug 30 18:39:15 BRST: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby removal (raw-event=PEER_NOT_PRESENT(3))
.Aug 30 18:39:15 BRST: %REDUNDANCY-3-STANDBY_LOST: Standby processor fault (PEER_DOWN)
.Aug 30 18:39:15 BRST: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected standby down or crashed (raw-event=PEER_DOWN(2))
.Aug 30 18:39:15 BRST: %REDUNDANCY-3-STANDBY_LOST: Standby processor fault (PEER_REDUNDANCY_STATE_CHANGE)
.Aug 30 18:39:15 BRST: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby removal (raw-event=PEER_REDUNDANCY_STATE_CHANGE(5))
.Aug 30 18:39:15 BRST: SWITCH-DELETE sequence complete, switch 2
.Aug 30 18:39:16 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel13, changed state to down
.Aug 30 18:39:16 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel14, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/3, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/4, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/5, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/6, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/7, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/8, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/9, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/10, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/11, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/13, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/14, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/15, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/16, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/17, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/18, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/21, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface Port-channel13, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/22, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface Port-channel14, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/23, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/1, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/2, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/3, changed state to down
.Aug 30 18:39:17 BRST: %LINK-3-UPDOWN: Interface GigabitEthernet2/1/4, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/3, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/4, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/5, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/6, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/7, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/8, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/9, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/10, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/11, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/13, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/14, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/15, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/16, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/17, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/18, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/21, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/22, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/23, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/1, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/2, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/3, changed state to down
.Aug 30 18:39:18 BRST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1/4, changed state to down
