can login to Jabber Web SDK possible without password?
jeff000079
We are authenticating the username/password against LDAP, before loging into Jabber Web SDK. The CUCM also uses the same LDAP. Is that possible to login without giving any password? Even if args.authenticate is set as true, login fails. I am not looking for SSO login yet.
Any suggestions welcome.
regards
Jeff
jocreed
I know this would be possible using the SAML login protocol from a direct XMPP/Jabber application, so I would think it would be available in the Jabber SDK, but let me confirm this.
Jeff,
It is currently not supported through the Jabber SDK, however, it is on the roadmap to be added to the SDK.
let us know if you have any other questions.
thank You,
Jock
npetrele
As Jock said, SSO is not built-in with Jabber SDK.  It shouldn't be impossible to implement it on your own, but I haven't been able to try it, myself.  Jabber SDK does support SASL.  I'm not sure if that would help with your requirements.
