Cisco Jabber integration with Node JS
k.iqzas
I am trying to integrate Node JS Application with Cisco Jabber.
I am not able to find a clear of doing it. I have searched various forums but still not able to reach a working example.
We use cisco jabber in our organization and the connection status is shown as below:
Address:some.webexconnect.com (IPV4)
Protocol: XMPP
and port.<port no>.
are these details enough to create to Cisco Jabber client using Node JS?
We use to login through SSO. do we need something special for SSO authentication.
Thanks & regards
K A Mohamed Iqzas
dstaudt
For Node JS, you will likely want to look for an XMPP Node JS library...it looks like there are at least a few listed here: https://xmpp.org/software/libraries.html
SSO, especially with WebEx Connect, may be tricky as there is no Cisco developer documentation covering XMPP integration in detail or WebEx SSO in particular.
