Conference room with two Webex Room Kits Pro
Hi all,
Does anyone have or know what are the xAPI macros that are required to integrate two Webex Room Kit Pro under a master-slave configuration scheme?
These two Webex Room Kit Pro were installed in a conference room which, in turn, has two separate rooms. The rooms can be used as single or combined rooms.
We need the customer to have two widgets or buttons on each Touch 10 panel so that they can choose between individual or combined scenarios.
Attached is the video connections diagram that we are using as an example. The only difference is that we are not using Quadcams.
We don't need to xAPI code for audio routing. We only need the macros for video routing.
Can anyone help us please?
Thanks in advance.
Best regards!
Alexander Stevenson
Hello rodrigo.prez@la.logicalis.com,
Awesome xAPI is a curated list of developer resources for Webex Room and Desk Devices. There are a lot of information and samples there.
I found that repo above in this presentation PDF from Cisco Live titled Customizing
Cisco Collaboration Devices which has many references to the xAPI macros for Webex Rooms.
I hope this helps.
