04-03-2014 12:34 AM
I'm trying to use the CUNI SOAP API to subscribe to CUC. I followed the article Parameter values in the CUNI Subscribe Web Method,
made a lot of attempts, but it still gives me error <faultstring>unknown</faultstring>.
The request is as follows:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:even="http://unity.cisco.com/messageeventservice/event" xmlns:even1="http://event.messageeventservice.unity.cisco.com">
<soapenv:Header/>
<soapenv:Body>
<even:subscribe>
<even:resourceType/>
<even:eventTypeList/>
<even:resourceIdList/>
<even:callbackServiceInfo>
<even1:callbackServiceUrl>http://192.168.6.61/webmail</even1:callbackServiceUrl>
</even:callbackServiceInfo>
<even:expiration>2015-10-26T21:32:52</even:expiration>
</even:subscribe>
</soapenv:Body>
</soapenv:Envelope>
RAW data:
POST /messageeventservice/services/MessageEventService HTTP/1.1
Host: 192.168.6.169
Authorization: Basic QWRtaW5pc3RyYXRvcjpJY2UyM3dhcnA=
connection:close
Content-Length: 644
Content-Type: text/xml
SOAPAction:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:even="http://unity.cisco.com/messageeventservice/event" xmlns:even1="http://event.messageeventservice.unity.cisco.com"><soapenv:Header/><soapenv:Body> <even:subscribe> <even:resourceType/> <even:eventTypeList/> <even:resourceIdList/> <even:callbackServiceInfo> <even1:callbackServiceUrl>http://192.168.6.61/webmail</even1:callbackServiceUrl> </even:callbackServiceInfo> <even:expiration>2015-10-26T21:32:52</even:expiration> </even:subscribe></soapenv:Body></soapenv:Envelope>
The corresponding response: (RAW)
HTTP/1.1 500 Internal Server Error
Content-Type: text/xml;charset=UTF-8
Transfer-Encoding: chunked
Date: Thu, 03 Apr 2014 07:11:44 GMT
Connection: close
Server:
112
<?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server</faultcode><faultstring>unknown</faultstring><detail /></soapenv:Fault></soapenv:Body></soapenv:Envelope>
Please do you have any hints how to solve this?
Josef Andrysek
Solved! Go to Solution.
04-23-2014 12:47 PM
I just did a quick test using the CUNI SDK (available via NuGet) and captured the output against my 10.0 server (details below). If you’re interested in using the CUNI SDK for testing and such check out the home page here:
http://www.ciscounitytools.com/CodeSamples/Connection/Notifications/NotificationSdk.html
there’s some training videos to help get you started but in short about 10 lines of code will get you monitoring message event notification – doesn’t get any easier. And if you’re developing in Java or Python or whatever you can use it as a test bed (a number of sites I work with use the various REST SDKs for this purpose).
Anyway – my Connection server is “192.168.0.188” here and I’m setting up a notification callback to my Windows 7 dev box at “192.168.0.99”. I’m telling it to monitor “operator” and “jlindborg” mailboxes (aliases for users on the Connection server). The request and response details look like this:
Request:
POST http://192.168.0.188/messageeventservice/services/MessageEventService
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<subscribe xmlns="http://unity.cisco.com/messageeventservice/event">
<resourceType />
<eventTypeList xsi:nil="true" />
<resourceIdList>
<string>operator</string>
<string>jlindborg</string>
</resourceIdList>
<callbackServiceInfo>
<callbackServiceUrl xmlns="http://event.messageeventservice.unity.cisco.com">http://192.168.0.99:8080/MessageEvent/AllEvents</callbackServiceUrl>
<hostname xmlns="http://event.messageeventservice.unity.cisco.com">192.168.0.99</hostname>
<password xsi:nil="true" xmlns="http://event.messageeventservice.unity.cisco.com" />
<protocol xsi:nil="true" xmlns="http://event.messageeventservice.unity.cisco.com" />
<sslCertificates xsi:nil="true" xmlns="http://event.messageeventservice.unity.cisco.com" />
<username xsi:nil="true" xmlns="http://event.messageeventservice.unity.cisco.com" />
</callbackServiceInfo>
<expiration>2014-04-25T12:26:37.1445312-07:00</expiration>
<keepAliveInterval>1</keepAliveInterval>
</subscribe>
</soap:Body>
</soap:Envelope>
Response:
<soapenv:Body>
<ns2:subscribeResponse xmlns:ns2="http://unity.cisco.com/messageeventservice/event">
<ns2:out>
<ns1:subscriptionId xmlns:ns1="http://event.messageeventservice.unity.cisco.com">ab260b3e-3923-440e-b0d0-d1f8b86cfd8a</ns1:subscriptionId>
</ns2:out>
</ns2:subscribeResponse>
</soapenv:Body>
</soapenv:Envelope>
04-23-2014 12:47 PM
Request:
<soap:Body>
<resourceType />
<resourceIdList>
</resourceIdList>
</subscribe>
</soap:Body>
</soap:Envelope>
Response:
<soapenv:Body>
<ns2:out>
</ns2:out>
</soapenv:Body>
</soapenv:Envelope>
04-24-2014 03:36 AM
Thank you very much. I discovered that the problem was sending empty <resourceIdList/>. I found somewhere that this enables notifications for any account, but it seems that it is not supported by CUC. The SDK is also very useful.
04-24-2014 06:58 AM
Originally there was supposed to be the ability to register for all users on the box but keeping this updated as users were added and removed across potentially multiple subscriptions was a little problematic - so static lists of aliases are required for each subscription - at least one at a minimum.
