CUPI - create a SMTP Notification Device without Event Type
fabien.bonic
Level 5
Level 5
I want to create a SMTP Notification Device for a User Template without any "Event Type" using CUPI.
According to a GET request on an existing Notification Device, I have to use an empty string for "EventList".
Here is the content body, I send:
        "SendCount": "false",
        "SmtpAddress": "smtpaddress@test.fr",
        "Active": "true",
        "DisplayName": "testsmtp",
        "MaxBody": "512",
        "MaxSubject": "64",
        "SubscriberObjectId": "864ba323-0a65-44aa-a6ff-5e5471afea4e",
        "SendCallerId": "false",
        "SendPcaLink": "false",
        "Undeletable": "false",
        "EventList": "",
        "ScheduleSetObjectId": "4b794a3e-7b91-40d4-9306-2fa13826bdde",
        "InitialDelay": "4",
        "RepeatInterval": "5",
        "RepeatNotify": "true",
        "VoiceMessage": "false",
        "UrgentOnly": "false"
And the response:
        "errors":
            "code": "INVALID_PARAMETER",
            "message": "Unrecognized event: "
Why the empty string is not accepted in creation whether it's accepted in modification? This looks like a bug?
Fabien
lindborg
if you remove the EventList property entirely it will create the device - however it will default to "All Voice Messages" being flagged if you don't pass anything in.  It's not typical to have a notification device with no event triggers on it - it's more proper to create it as not enabled vs. enabled with no event types defined - which is probably why the create new method barks about that.
lindborg
