05-02-2014 01:48 PM
Playing with Jabber SDK Samples, I noticed most of them pass plain text passwords in JavaScript to authenticate against CUCM.
Looking at the JSDoc, this is also possible:
jQuery(
'#phone'
).cwic(
'registerPhone'
user:
'fbar'
password: {
encoded:
'GJH$&*"@$%$^BLKJ=='
cipher:
'cucm'
mode:
'DeskPhone'
cucm:
'1.2.3.4'
success:
function
(registration) {
console.log(
'registered in mode '
+ registration.mode);
console.log(
'registered with device '
+ registration.device.name);
https://developer.cisco.com/media/JabberVoiceAndVideoAPI/symbols/$.fn.cwic.html
What method is used to encode the password string? It does not seem to be standard base64. I would like to encode the password when the user logs in so that when he/she reaches a page with Jabber SDK integration, I can simply pass the encoded string.
05-12-2014 10:55 PM
As you have mentioned based on the url https://developer.cisco.com/media/JabberVoiceAndVideoAPI/symbols/$.fn.cwic-settings.html
we can see from the following url https://developer.cisco.com/media/JabberVoiceAndVideoAPI/symbols/src/src_www_src_cwic_cwic.js.html
that
if (typeof password === "string") {
// clear password, encrypt it
password = { cipher: 'cucm', encrypted: _plugin.api.encryptCucmPassword(args.password) };
if (registration.authenticate) { clearPassword = args.password; }
} else if (typeof password !== "object" || (password.cipher !== "cucm" && password.cipher !== "base64")) {
return _triggerError($this, registering.errorCb, errorMap.InvalidArguments, 'invalid password (type ' + typeof password + ')', { registration: registration });
// make preferredDevice a string (possibly empty)
var preferredDevice = args.device || _plugin.api.PreferredDevice;
if (typeof preferredDevice === "object") {
preferredDevice = (preferredDevice.name ? preferredDevice.name : '');
Thanks and Regards,
Geevarghese
05-28-2014 09:32 AM
Good find!
Just to clarify a bit, the Jabber SDK plugin itself (when installed and loaded) exposes a function that can encrypt using the 'cucm' cipher:
_plugin.api.encryptCucmPassword(password)
This function is undocumented (as are all of the bare plugin APIs), and I assume is mainly intended for use by the Jabber SDK javascript library internally to avoid credentials being sent over the wire in the clear (i.e. when the plugin executes registration steps.)
Normally one would expect the user credentials to be gathered from the user rather than hard-coded in the page HTML/JS. Note that 'base64' appears to be third 'cipher' supported by the plugin.
