"osd mode: indicators"
vidar.hauglien
Hi.
I know this was asked for in 2011 (OSD status indiactors), but i was wondering if it is now possible to activate the limited OSD mode that is shown when using Cisco Touch, or at least simulate that a Cisco Touch panel is paired to activate the limited OSD mode?  Does it exist any documentation for the pairing process?  This is for Crestron Integration.
- Vidar Hauglien
This might be possible with the following command:
xConfiguration Experimental SystemUnit MenuType: <Auto, Indicators, Interactive>
However if you enable it to use "indicators", it will display the following on the codec if no touch panel is used.
Connection with the touch screen is lost
> Ok
> Unpair and restart
If you want to use this, you might want to contact your Cisco Account Manager and see if they can open a feature request to disable the touch panel warning.  I know they did this for the new SX80 when anyone would like to use it with an external control system such as Crestron or AMX.
Geevarghese Cheria
Hi Vidar,
    You can find the related documentation here -
https://developer.cisco.com/site/collaboration/telepresence/av-integrator/home/
Hi.
This is not in the documentation, that is why i ask here.
- Vidar
> Ok
> Unpair and restart
Thanks! This is exactly what i was after.
