Reverse Proxy Nginx with co-browse problem
snetykkim
I have got a working lab model for the RE Mobile.
Everything works fine on the internal network.
I have now included the Nginx Reverse Proxy and tried calling via the Internet using a web browser but there are issues with co-browse.
The call gets routed in to the Finesse Desktop.
When I click the co-browse on the Finesse Desktop, the customer can't see the requested alarm.
It only appears when I try it through a reverse proxy server.
Please advice me.
Below is my Nginx configration :
server {
                listen 80;
                #listen 8080;
                listen 443 ssl;
                listen 8443 ssl;
                server_name rem.domain.co.kr;
                ssl_certificate /etc/nginx/certificate.crt;
                ssl_certificate_key /etc/nginx/privateKey.key;
                location / {
                proxy_pass https://10.0.9.101:8443/assistsample/$request_uri;
               # root /usr/share/nginx/html;
               # index index.html index.htm;
                #REQUIRED FOR CSDK SESSION REQUEST
                location /gateway/ {
                proxy_http_version 1.1;
                proxy_set_header Upgrade $http_upgrade;
                proxy_set_header Host $http_host;
                proxy_pass https://10.0.9.101:8443$request_uri;
                #REQUIRED TO ALLOW CROSS DOMAIN REQUESTS
                add_header 'Access-Control-Allow-Origin' "$http_origin";
                add_header 'Access-Control-Allow-Credentials' 'true';
                add_header 'Access-Control-Allow-Methods' 'GET, POST, PUT, DELETE, OPTIONS';
                add_header 'Access-Control-Allow-Headers' 'Accept,Authorization,Cache-Control,Content-Type,DNT,If-Modified-Since,Keep-Alive,Origin,User-Agent,X-Mx-   ReqToken,X-Requested-With';
                #REQUIRED FOR EXPERT ASSIST SAMPLE APP
                location /assistsample/ {
                location /expertassist/agent/ {
                location /assistserver/ {
rdoyle001
You will need to upgrade the assistserver for websockets....
rdoyle001
huliving
Sorry for the late response.
Expert assist creates a websocket to assistserver as well as /gateway/ so perhaps the following should be added to the location /assistserver/ section:
If that does not help it would be good to see the web browser console logs.
