System.Messaging.SDLAccessList.Enabled
funker
Level 5
Level 5
Is there document that talks about 'System.Messaging.SDLAccessList.Enabled' value?
smupadhy
I am not able to find a document that talks about "System.Messaging.SDLAccessList.Enabled". If you can elaborate on what you are trying to do, we may be able to suggest some alternate resources/documents.
jocreed
I have contacted the Unity Connection team to see if they are aware of where to find the documentation you are looking for.
The option in UI "Use Access Lists to Control Who Can Send to System Distribution Lists" is same as System.Messaging.SDLAccessList.Enabled'
