using CUCMessenger 1.0 COM component
stephan.steiner
I noted that there's a company pstech that offers a Notes plugin with Jabber integration, and apparently they're using COM to communicate with jabber. So I quickly fired up Visual Studio and lo-behold, there's that COM plugin. However, now I'd need some kind of documentation on how to use the component so as to get started. Is there anything around? I've gone through the Jabber dev center but haven't found anything that refers to techniques other than what can be done using the javascript based APIs.
Stephan
Geevarghese Cheria
Hi Stephan,
I was not able to find any document related to CUCMessenger 1.0 COM component. Hope this url - Cisco Jabber Integration Plug-In for Lotus Notes | Cisco Technical Support Forum  will give some related information.
Thanks and Regards,
Geevarghese
