cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Parser View
sebamegot
Hello community.
I have a problem configuring a view table on a cisco switch, I have defined all the commands that can perform the user in question, however when trying to restrict the creation of vlans with the following commands "commands configure exclude vlan" and the alternative "commands configure exclude vlan all" the view user can continue creating vlans, I'm not sure if it's a bug or I'm placing the command wrong.
It should be noted that you have the permission to associate the vlan to a port, I doubt it is linked to the fact that because of that command you can also create vlans.
I appreciate the help
0 RESPUESTAS 0
