CiscoLineDevSpecificMsg.h
stefan.eckel
Community Member
Hello!
Where can I find the current version of the CiscoLineDevSpecificMsg.h file which contains the extensions for CALLINFO. The only file I have found in a Cisco TAPI sample is quiet old and does not contain any CALLINFO related structs.
Taking the code out of the TapiDevGuid fails because the type TSP_UNICODE_PARTY_NAMES is not known and I have not found it in anywhere.
typedef struct Cisco_LineCallInfo_Ext00060000
TSP_UNICODE_PARTY_NAMES unicodePartyNames;
} CISCO_LINECALLINFO_EXT00060000;
Thank you for your help.
Stefan
Axel Becker
Community Member
Hi Stefan,
it should be part of the TSP installation.
best regards
Axel
