3750G switch will not boot up correctly
Jose Jusino
           When it tries to boot up it has random characters show up.......Not acting like it should....
Jose Jusino
I have tried changing speed to see if it was a speed issue but it makes no difference.....
Does it boot to an operational state?  Can you telnet to it?
What speeds did you try?  Newer hardware may use a 115200 console speed.
Possible speeds in newer hardware:
 0 = 9600,  1 = 4800,  2 = 1200,  3 = 2400
 4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200
See
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008009433b.shtml
If none of those speeds work, make sure that you have hardware flowcontrol off on your terminal emulator and also that the console works on other Cisco devices (to make sure wiring is OK).
If all of that fails, you may have a hardware issue.
