ASR9922 - Replacing power modules v2 to v3
jginer
Hello
We need to replace the PEM and power modules from PWR-2KW-DC-V2 to PWR-4.4KW-DC-V3 in an ASR9922 (XR 6.1.4), but the procedure documented in the "Cisco ASR 9000 Series Aggregation Services Router Hardware Installation Guide" does not include the replacement on the chasis 9922 and 9912 because as it was detected on the bug CSCvf79876, the "pwrmod_change" script is not longer supported on those chasis.
Could you please advice how would be the rigth procedure for the 9922 if the script cannot be executed? or is not longer needed to replace EEPROM values before replacing the PEM and Power supplies?
Thanks.
0 Replies 0
