authentication on nexus with local than radius
Erik Molnar
Dear All,
On IOS we can configure that the authentication should check the local database first and than than the RADIUS ( it's a RSA server ) if the user is not available on local database.
This is needed for PRIME because it uses a local user for configuration archiving.
However this is not possible to configure on Nexus.
We checked 5.2 and on 7.0 but the issue is the same.
Is there a way that this behaviour to be changed by some configuration change? Or will it be added as an enhancement in the future?
Thank you in advance.
Best Regards,
Erik Molnar
0 Replies 0
