CSCto14401 - SCP doesnt work for mult-context mode
This is simply not good enough, and yet another example of the sloppiness in supporting everyday run-of-the-mill functionality in multi-context environments (the list of features that were, and still are, missing in multi-context mode is infuriating).
OK, file-access is restricted to the SYS context. Not a problem - you already do network (client) operations for SYS context using the IP-address(es) of ADMIN (ntp, tftp, network file copy). Extending that to SCP server (and the matching required AAA) is trivial.
Sure, I could code my way around it by sending ssh commands that copies the other way - BUT I DON'T WANT TO. I don't want to involving the authentication space of the Linux machine doing the work. I use specially designated machine accounts that are only valid for TACACS login while coming from exactly that Linux machine.
So kindly "unterminate" the bug and start coding.
navtom
Where are we with this bug 4 years later?
