CSCus02070 Flex Ap losing Vlan Mapping and falling on default vlan
Laloutre
I think I'm facing this bug but I'm currently running version 8.0.140.0
In the bug this IOS is not known as affected but the symptoms are the same.
Anyone has the same issue with others versions identified in the bug ?
In the bug it's indicates that there is no known fixed release. So I have to reconfigure the vlan mapping until a fix is found ?
Thanks for your help
smace
I'm also having the same problem on version 8.0.140.0. I know this is happening on model 2602 access points. Not sure if it's happening on 3702 models.
craigbr
Think this has been an issue for some time. Been running Cisco controller for 9 years and since moving to Flexconnect from H-REAP have had this randomly occur and with sites with 50 AP's in a 1 floor building is a pain. I did read an article that mentioned moving the AP's into Flexconnect groups vs. AP groups to resolve the issue.
jayage
We do have the same symptoms appearing sporadically on several 2702 APs. Controllers are 5508 with version 8.3.140.0
We're now moving from AP- to Group-specific configuration...
