CSCux01471 - snmp-lib-ipc detected Not enough memory'.
edenilson.perin
Is there any solution for this? I'm using the ios verion 6.2.3 and I'm getting a lot of timeouts in my SNMP queries. It started happening after I added the "ifmib ipsubscriber" command in order to monitor my subscribers.
jigojar
HI,
 I am also facing the same issue. do we have any solution.
show snmp trace packet
Tue Sep 17 21:34:44.212 IST
Entering snmp_ltrace main....
4154 wrapping entries (4160 possible, 0 filtered, 33100662 total)
Sep 17 21:34:12.661 snmp/packet 0/RSP0/CPU0 30463033# t11 ERROR: Internal Dispatch failed at tp = 0 for reqID 1402973718 : (rc = 3487400448) 'snmp-lib-ipc' detected the 'resource not available' condition 'Not enough memory'
Sep 17 21:34:12.661 snmp/packet 0/RSP0/CPU0 t11 ERROR: Internal Dispatch failed for 100.96.215.18,30876 (reqID 1402973718) 'snmp-lib-ipc' detected the 'resource not available' condition 'Not enough memory'
Sep 17 21:34:12.661 snmp/packet 0/RSP0/CPU0 1659060# t11 ERROR: Internal Dispatch failed at tp = 0 for reqID 1402973750 : (rc = 3487400448) 'snmp-lib-ipc' detected the 'resource not available' condition 'Not enough memory'
Sep 17 21:34:12.661 snmp/packet 0/RSP0/CPU0 1790358# t11 ERROR: Internal Dispatch failed for 100.96.215.18,30876 (reqID 1402973750) 'snmp-lib-ipc' detected the 'resource not available' condition 'Not enough memory'
