CSCux99539 - Intermittent error message "Power supply 2 failed or shutdown"
amocherla
We are seeing the same behavior on Cisco 6.0(2)U3(7) / cisco Nexus 3064.
Could you please confirm that it is a known bug for this version as well.
StanAdam1
System Ver: 7.0(3)I3(1)
%KERN-3-SYSTEM_MSG: [80134397.059203] pfmclnt/11060 - failed to set mux a
ddr 0x70 ch 2 err I2C_ERR_NO_RESPONSE - kernel
2019 Apr 9 01:01:33
%PLATFORM-2-PS_REMOVE: Power supply 2 removed (Serial number xxxxxxx)
%PLATFORM-2-PS_CAPACITY_CHANGE: Power supply PS2 changed its capacity. possibly due to On
/Off or power cable removal/insertion (Serial number xxxxxx)
%PLATFORM-2-PS_RED_MODE_CHG: Power supply operational redundancy mode changed to non-redu
ndant
Have the same issue. Cisco TAC replaced the PS and still same issue. Any help will be much appreciate it!
strou
I have the same issue.  Did you get any help?  How did you solved the issue?  Reboot? Replace?
Steve
