CSCvb87210 - Need to increase timeout for WLC Configuration Archive - 1
Sharath Karpur
Hello All,
I am too facing from error with Cisco prime jobs failing, could someone help how to solve this.
Error : Function run timeout 180000 ms
Sharath
juancho386
When I try to run a Job to get the WLC5508 archive configuration, the "Last Run Status" show "Partial-Success", then looking on details, the "Fetch Startup" show Function run timed out 60000ms
I've figured out that when I try in the WLC CLI "show run-config startup-commands", It take about 160 seconds.
Cisco Prime is not able to wait the configuration answer from the WLC because the WLC takes a long time to process It.
juancho386
In PRIME, In the list devices, edit the device and try changing the SSH timeout to a higher time. This could be a solution. It worked for me with a WLC.
