CSCvb93881 - Major alert F0409 Thermal condition on chassis x is upper-critical' caused by ASIC Temp on IOM 2300
dedy.yuliady88
I am facing this issue. This bug ID mention that this bug fix on UCSM 3.1 but in my environment that running 4.1(2) still facing this issue on several chassis.
cae_technology
Hey,
I came across this as i was looking into something similar but saw no response so will try to help you out.
1. Did you get an F0410 alert after? If so nothing to worry about. Otherwise, you need to do some checks.
2. The checks are what you defined as temperature remember in 4.1 this is not defined thus you can set it up go into Servers > Policies >  Threshold Policies unless you already have one then you need to change the value.
3. Familiarise yourself with the architecture b or c series. For example, b series is designed in a way that air goes to first cpu then the second so expect as standard behavior second cpu to have a higher temperature. c series is alot better
KR,
