CSCve21378 - 2960x - Power Controller reports power Tstart error detected
michael.preiss
I have the same issue.
No intension to fix this from cisco side?
5 Replies 5
pfuhrmann82
Did you try to update to 15.2.2E7?
If this does not work, try a downgrade to a version before 15.2.2E5
hello,
For information, i have upgrade lots of switch in 15.2(7)E2, issue is still the same.
Best regards
i am facing the same issue  with cisco 2960X, anybody contacted TAC regarding this ?  what is the reply from TAC on this ?
carlos.ramos
Does anyone know if this was ever fixed? I can't find any version that specifically states it fixes this issue.
awomack11
Is this only happening on a single port? This discussion suggests the message could be caused by a faulty network cable.
