CSCvf25144 - 2960X - Reload causes member switches to get stuck in initializing%2C interfaces down%2Fdown
gcastillo
The BUG report only mentions 15.2(2)E5, but we are experiencing the same issue with 15.2(2)E7
Leo Laohoo
I recommend you raise a TAC Case so they can investigate further and add your case into the "register".
Andre Hohler
Hello
We had the same issue.
Release 152-4.E6 has solved the problem. In some cases we had to power off the stacks for 2 minutes after the upgrade. But after these procedure the problem was gone.
