CSCvf36434 - Resizing Access Control Policy Column Headers Does Not Resize Rows
p.obourdin
This appears to happen on wide-screens or high-resolution screen as well.
I'm not sure whether or not the 'zoom level' has anything to do with this...
Is this the only workaround that is available? Change the zoom level? It's not working for wide and high resolution screens...
JBXTEX
If your window is 'maximized' you will not be able to adjust the columns..  The way I get around this is shrinking the browser window about 2/3's of its maximized size.  The columns will redraw as they should..  Once they are at the desired width, you can re-maximize the window
