CSCvg48903 - 8.62702/3702 Radio reset with reset codes changing aggressively, cannot be understood by customers - 1
jloredot1
I think I have the same problem. but with an AP AIR-CAP1532E-A-K9.
* Sep 12 18: 29: 46.175: Starting Ethernet promiscuous mode
* Sep 12 18: 29: 46.207:% LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
* Sep 12 18: 29: 46.223:% DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
* Sep 12 18: 29: 46.231:% DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
* Sep 12 18: 29: 46.235:% DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 27
* Sep 12 18: 29: 46.235:% DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 27
* Sep 12 18: 29: 46,259:% LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
* Sep 12 18: 29: 46,259:% LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
* Sep 12 18: 29: 46.263:% DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
* Sep 12 18: 29: 46.263:% DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
* Sep 12 18: 29: 46.299: SCHED: Ethernet Bridge Process: remove watched boolean System Initialized (62968D74)
* Sep 12 18: 29: 46.299: SCHED: Ethernet Bridge Process: install watched queue Soap BVI input queue (6529B3BC), os: 0 ah: 0
* Sep 12 18: 29: 46.299: No configuration in NVRAM..Auto Install initiated ..
* Sep 12 18: 29: 47.251:% LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
* Sep 12 18: 29: 47.259:% LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
* Sep 12 18: 29: 47.259:% LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
* Sep 12 18: 29: 58.211:% LINK-6-UPDOWN: Interface BVI1, changed state to down
* Sep 12 18: 29: 59.211:% LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
The AP is in stand alone mode. The problem happens at all times, even if the AP is not configured.
rchockeelopez
Hi, I am having a similar problem with an AP model: AIR-AP1572EAC-N-K9 Could you tell me if there is a solution or not? Thanks,
