CSCvg48903 - 8.62702/3702 Radio reset with reset codes changing aggressively, cannot be understood by customers - 2
We also see this issue happening with 8.8.111 version as well. Is there any fix for this?
*Jan 9 08:36:13.979: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 27
*Jan 9 08:36:13.979: %WIDS-6-DISABLED: IDS Signature is removed and disabled.
*Jan 9 08:36:14.099: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - EASY_ADMIN is not set, turn off easy admin service!
*Jan 9 08:36:14.099: %CAPWAP-5-AP_EASYADMIN_INFO: AP Easy Admin information - Easy Admin is not enabled, turn it off!
*Jan 9 08:36:14.111: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 39
*Jan 9 08:36:14.111: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 39
*Jan 9 08:36:14.123: %CLEANAIR-6-STATE: Slot 0 down
*Jan 9 08:36:14.123: %CLEANAIR-6-STATE: Slot 1 down
*Jan 9 08:36:14.127: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jan 9 08:36:14.127: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jan 9 08:36:14.127: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Jan 9 08:36:14.135: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 9 08:36:14.735: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Jan 9 08:36:14.755: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
- Michael Duong
Leo Laohoo
Try 8.8.125.0.
rchockeelopez
Hi, I am having a similar problem with an AP model: AIR-AP1572EAC-N-K9 Could you tell me if there is a solution or not?
