CSCvg48903 - 8.62702/3702 Radio reset with reset codes
rchockeelopez
Hi, I am having a similar problem with an AP model: AIR-AP1572EAC-N-K9 Could you tell me if there is a solution or not? Thanks,
this is not fixed and marked as unreproducible , which means that Cisco engineering/TAC has not seen it with customer again and also not able to reproduce it themselves..
Your best bet is to open a TAC case and let TAC investigate along with engineering to get to the bottom. Should be easy if this is happening frequently..
**Please rate as helpful if this is really helpful**
