CSCvm96943 - SS: AP does not join 9800 WLC through 9124axd PSE port
almansoorim
AP not joining and logs showing the cycle below.
This is 9120axi AP and uplinking through the "1 Gig PSE (PoE-OUT) Ethernet Port" of the 9124axd
FYI, different APs tested with the same behavior and the 9124axd AP joins the WLC normally and it is on a UPoE switch
[*07/03/2023 18:47:42.1510] ===> Activate Deep Green Mode
[*07/03/2023 18:47:42.1510] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*07/03/2023 18:47:43.4520] chatter: Device wired0 notify up link DOWN
[*07/03/2023 18:47:44.2570] <=== Deactivate Deep Green Mode
[*07/03/2023 18:47:44.2570] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*07/03/2023 18:47:44.2570] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*07/03/2023 18:47:44.2580] chatter: Device wired0 notify state change link UP
[*07/03/2023 18:47:58.4820] chatter: Device wired0 notify down link UP
[*07/03/2023 18:47:58.5070] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link DOWN.
[*07/03/2023 18:47:58.5070] ===> Activate Deep Green Mode
[*07/03/2023 18:47:58.5070] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*07/03/2023 18:48:00.5020] chatter: Device wired0 notify up link DOWN
[*07/03/2023 18:48:00.6130] <=== Deactivate Deep Green Mode
[*07/03/2023 18:48:00.6130] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link UP
[*07/03/2023 18:48:00.6130] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link Up at 1000 mbps full duplex
[*07/03/2023 18:48:00.6130] chatter: Device wired0 notify state change link UP
[*07/03/2023 18:48:15.5350] chatter: Device wired0 notify down link UP
[*07/03/2023 18:48:15.5360] chatter: Device wired0 notify down link UP
[*07/03/2023 18:48:15.9670] wired0 (Ext switch port: 7) (Logical Port: 15) (phyId: 1f) Link DOWN.
[*07/03/2023 18:48:15.9670] ===> Activate Deep Green Mode
0 Replies 0
