CSCvn64652 - Cisco Identity Services Engine Cross-Site Scripting Vulnerability - 2
user101111
The bug report states 2.4(0.908) is a known fixed release, however I'm not seeing this patch listed in the software download section. The latest available patch is Patch 9 (906). Is this a typo in the bug report or will an updated patch be released?
This bug was noted as resolved in the Release notes in Ise 2.4(0.357) Patch 8, so patch after that will also include this fix. Such as Patch 8-9, so it looks like a typo.
ISE 2.4(0.357) Release Notes
Resolved Caveats in Cisco ISE Release 2.4.0.357- Cumulative Patch 8
The following table lists the resolved caveats in Release 2.4 cumulative patch 8.
Patch 8 might not work with older versions of SPW. MAC users must upgrade their SPW to MACOSXSPWizard 2.2.1.43 or later, and Windows users must upgrade their SPW to WinSPWizard 2.2.1.53 or later.
Note
After the patch is successfully installed, sometimes you may see an alarm indicating that patch installation failed with an error while trying to reboot. This is a false alarm. You can ignore this alarm.
 Caveat ID NumberDescription
CSCvj83362
Include hostname in posture assessment reports
CSCvk34232
Posture remediation files are limited to 50MB
CSCvn35142
ISE 2.3 : Posture report for endpoint by condition not working as expected
CSCvn44171
Network access user with external password cannot be used as ISE admin
CSCvn52886
User name from WMI information is deleted on receiving a DHCP custom syslog for same endpoint
CSCvn55560
ISE 2.3 after applying patch 5 creation of EOB Guest user does not work
CSCvn56648
When individual policy set is reset, other policy set hit counters are reset to 0.
CSCvn58964
ISE 2.4 slow database response with 500 authorization policies
CSCvn60787
Emails are not sent for alarm specific email configuration
CSCvn61139
Smart Licensing agent thread lock causes GUI login delay in ISE 2.2
CSCvn64652
Note
CSCvj83362
CSCvk34232
CSCvn35142
CSCvn44171
CSCvn52886
CSCvn55560
CSCvn56648
CSCvn58964
CSCvn60787
CSCvn61139
CSCvn64652
